Ultrasonic receiver circuit diagram for echo detection distance
Source: InternetPublisher:拿铁三分糖 Keywords: ultrasonic ranging circuit diagram transistor Updated: 2021/04/22
The operating voltage of this circuit is 9V, the current consumption is only 5mA, the frequency can be adjusted within the range of 150 to 180kHz, and the bandwidth is about 20kHz to ensure that only pulses wider than 70us can pass through and be amplified.
The receiver input terminals are directly connected to the sensor and thus to the oscillator. When an ultrasonic pulse occurs , the signal voltage at the base of T1 is limited to a lower value by diodes D1 and D2. Transistors T1 and T5 form a two-stage high-frequency amplification, which is then rectified by D3 to control the output transistor T6 as a threshold switch, whose threshold is adjusted by R6. Transistors T2, T3, and T4 are additional stages used to control the first high-frequency stage.
Transformer winding data: terminals 6 to 1: 200 turns, 0.03mm copper enameled wire; terminals 3 to 2: 95 turns, 0.03mm copper enameled wire.
- Share the features of Wi-Fi 6 that you don’t know
- How to use FPGA and RS485 for industrial communication
- DIY a network router
- Convenient and practical electric guitar wireless transmitter
- Pocket Wireless Microphone
- WE800 FM/FSK 1~0.1 GHz Transmitter
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- rfHCS362G/362F ASK/FSK 440~310 MHz KEELOQ Code Hopping Transmitter
- Stereo FM transmitter circuit designed with BH1417
- Crystal controlled local oscillator circuit diagram
- Capacitive feedback oscillator circuit
- Signal level status display circuit
- Three-phase motor phase failure transistor protection circuit
- Bridge motor drive circuit
- Ground drain amplifier circuit connections
- transistor voltage amplifier ac current
- A single-section transistor performance test circuit
- One of the no-load automatic stop circuits of transistor type AC arc welding machine
