Fish tank oxygenation timer circuit
Source: InternetPublisher:newrudeman Updated: 2017/06/17
Nowadays, many people like to keep fish in their homes. I think the following things may be useful. I wanted to make this thing when I saw something similar when I was playing at a friend's house. My friend's fish tank doesn't have many fish, so he doesn't need to turn on the oxygenator continuously, and he is too lazy to turn the oxygenator on and off every day, so he bought something similar to this. He wanted another one, so I made one for him. Circuit principle: The circuit is simple and mainly controlled by the microcontroller AT89C2051. The 220-volt AC power supply in the circuit is stepped down by the transformer, full-bridge rectified, filtered by C5 and C6, stabilized by the three-terminal voltage regulator 7805 and filtered by C7 and C8, to provide a stable 5-volt power supply to the microcontroller. LED2 is used to indicate circuit power status. LED1 is used to indicate whether the oxygenator is working. When the oxygenator is working, LED1 lights up. S1 is used for circuit reset. When the microcontroller crashes due to interference, you can press S1 to reset. S2 is used to set the time to turn on the oxygenator, the settable time is 1"29 minutes, S3 is used to set the interval time when the oxygenator does not work, the settable time is 1"5 hours, S4 is used to display all set time.
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- Servo motor pin diagram/working principle/application
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor control circuit for starting and running without phase loss
- Using P110C to control 6 DC motors simultaneously
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- "Watchdog" anti-theft alarm circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
