Home >
Detection Circuits >Instrumentation > Railway-specific 150MHz ultra-short wave interference direction finder circuit
Source: InternetPublisher:方世玉223 Updated: 2015/05/15
Part of the circuit of the 150MHz ultra-short wave interference direction finder developed and designed specifically for railways. The frequency output by the voltage-controlled oscillator in the FM receiver MC3363 is pre-divided by the dual-mode prescaler MC12017, and then output to the programmable parallel input phase-locked loop MC145152. , the microcontroller AT89C51 programs the MC145152 through the I/O port to change the initial counting value of its counter, thereby changing the frequency division ratio. The error signals φV and φr output by the dual output terminals of the phase detector are input to a first-level dual circuit composed of LM358. An active low-pass filter with terminal input, in which R10, R18, R12, C16, etc. constitute the RC low-pass link of the active filter input circuit, while R11 and C17 constitute the high feedback link of the active filter. The peak detector composed of D1 and C14, R9, and C15 networks further smoothes the error voltage output by the active filter, and then directly controls the voltage-controlled oscillator in MC3363, forming a complete numerically controlled phase-locked loop. The microcontroller receives the manually adjusted and set values, and presets the initial counter value of MC145152 differently to lock different frequencies and achieve the purpose of changing signals at different frequencies. After the signal corresponding to the frequency point is sent to the microcontroller through A/D, it is then input to the character display to display the signal field.
MC145152 frequency synthesizer and its application 1. Overview
MC145152 is a large-scale integrated circuit produced by MOTOROLA. It is a half-line code The input mode is set and the dual-mode CMOS-LSI phase-locked loop frequency synthesizer is programmed by 14 parallel input data. Its internal block diagram is shown in Figure 1. The chip contains a reference frequency oscillator, user-selectable reference divider (12×8ROM reference decoder and 12bit÷R counter), double-ended output phase detector, control logic, 10-bit programmable 10-bit ÷N counter, 6-bit programmable 6bit÷A counter and lock detection parts. Among them, 10bit÷N counter, 6bit÷A counter, analog control logic and external dual-mode prescaler form the pulse swallowing program frequency divider. The total frequency division ratio of the pulse swallowing program frequency divider is: D=VN+A. 2. Pin arrangement and function
The pin arrangement of MC145152 is shown in Figure 2. It is packaged in a 28-pin DIP, and the functions of each pin are as follows:
Pins 4, 5, and 6 (RA0, RA1, RA2) are the reference address code input terminals, used to select the frequency division ratio of the reference divider. Programming via 12×8ROM reference decoder and 12bit÷R counter. There are 8 choices for the frequency division ratio. The relationship between the reference address code and the frequency division ratio is shown in Table 1. Pins 26 and 27 (OSCIN, OSCOUT) are the reference oscillator terminals. When the two pins are connected to a parallel resonant crystal, a reference frequency oscillator is formed. However, a frequency setting capacitor (usually around 15pF) should be connected between OSCIN to ground and OSCOUT to ground. OSCIN can also be used as an input terminal for external reference signals. Pin 1 (VCO) is the input signal terminal. The input signal is AC coupled to this pin. The input signal frequency should be less than 30MHz. Pins 10 and 21~25 (A5~A0) are the frequency dividing terminals of the 6bit÷A counter. The preset number determines the number of ÷V/(V+1) dual-mode preamplifiers
. Pins 11~20 (N9~N0) are the frequency dividing terminals of the 10bit÷N counter. Pins 7 and 8 (φV, φr) are the dual output terminals of the phase detector, used to output loop error signals. If fV>fr or the phase of fV leads fr, φV becomes low level and φr remains high; if fV
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/50ac307a-3c63-11ec-b776-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/50aca5ac-3c63-11ec-a567-086126841eb8.jpeg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/50acf3cc-3c63-11ec-85ff-086126841eb8.jpeg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/50ad6900-3c63-11ec-926a-086126841eb8.jpeg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/50adde30-3c63-11ec-bb7f-086126841eb8.jpeg)
Latest Detection Circuits Circuits
- Make a Simple Darkness Detector Circuit
- Simple and easy to make zero degree detector
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Multi-speed current test circuit of transistor HFE
- LM3914 makes car battery detector
- Inductive Pointer Watch Battery Tester
- How to Use a Radio as a Metal Detector
- Homemade Metal Detector
- 1.5V and 9V battery tester circuit diagram
- Sample and hold circuit diagram
Popular Circuits
- LED lighting display detection circuit with overload protection
- Paper thickness detection circuit
- Pyrothermal infrared detection circuit composed of OPA111
- Simple infrared detection circuit
- Level detection circuit using digital-to-analog converter
- A5348 smoke alarm detection circuit - block diagram
- Photodetection circuit for DC recovery to suppress unwanted stable background light
- Differential light detection circuit
- Film thickness detection circuit using eddy current method
- Thin object presence/absence detection circuit
