Pyrothermal infrared detection circuit composed of OPA111
Source: InternetPublisher:难得正经 Keywords: OPA infrared detection circuit BSP Updated: 2021/06/26
Pyrothermal infrared ray is an application of non-contact temperature measurement of objects through infrared rays radiated by the object. Since
the detected signal is very weak, the sensitivity of the pyrothermal infrared sensor must be very high and the noise must be very
small; similarly , also has very high requirements on the amplification circuit, and ordinary operational amplifiers cannot meet the requirements. The
pyroheat infrared measurement circuit composed of OPA 111 is shown in the figure.
The structure of the circuit is like a general operational amplifier, except that the feedback resistor is very large (requiring a very
large gain); the signal leads and the copper foil traces of the signal pins on the printed circuit board must be shielded. Because the gain of the amplifier
is very large, external noise will cause interference if it is not shielded.
- Analysis of the flow direction of transistor current
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What does a rectifier do? What is the process of rectification?
- The Importance and Ideal Model of Impedance Matching
- How does sand become chips?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What are the parts of the fpga design process
- Working principle/advantages/disadvantages/size of optical fiber
- Important things to know about PCB routing and how to design the right routing for your PCB
- An example of proportional integral circuit diagram
- Analysis of rectifier circuit types and principles
- Electronic anti-asthma circuit
- Rural fish farming control circuit
- Biogas concentration detection line
- Farmland irrigation automatic control circuit a
- Mixer built with analog multipliers
- Frequency modulator composed of NE566
- Simple AGC circuit in transistor radio
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
