AC grid powered light emitting diode circuit diagram
Source: InternetPublisher:宋元浩 Keywords: LED power grid circuit diagram power supply Updated: 2021/06/01
The circuit simply consists of an integrated operational amplifier, a TCA335A, and a silicon photodiode BPX91. Using the BG38.2mm optical filter can make the photoode's sensitivity to light consistent with that of the human eye. Switch S is used to convert the range in decimal from 10*2 to 10*5 1x. The 100uA meter is used to indicate the value of illumination.
Main technical data: Working voltage Us: plus or minus 3V Working current Is: 0.5mA Full-scale measurement range B: 10*2~10*51x Temperature coefficient a: +0.2%/K Maximum output current I: <1mA
- Audio level LED and digital dual display circuit
- USB powered portable light
- Low illumination amplifier circuit
- Lighting lamp voltage stabilizing circuit (2)
- Corridor automatic light-off device
- Simple electronic doorbell circuit
- One of the bead-type emergency light circuits
- Gas and smoke alarm circuits with intermittent alarms
- Remote anti-theft alarm
- Touch/wireless remote control dimmer light circuit diagram
- Cordless phone anti-theft circuit
- Tree-trunk main wiring system diagram a
- Single-ended input circuit (5V power supply)
- Power indicator circuit
- Wiring c when the leakage protector supplies power to single-phase loads in the TN system
- Power supply coupler-thyristor interface circuit b
- Electromagnetic brake control circuit
- 8W+8W tube power amplifier
- Automatic delay power supply refrigerator protector circuit
- Circuit for supplying power to frequency counter via RS232
