Wiring c when the leakage protector supplies power to single-phase loads in the TN system
Source: InternetPublisher:D先生 Keywords: Wiring leakage protector power supply BSP Updated: 2020/01/22
TN system, that is, the neutral point on the power side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system neutral line N cannot be connected to the neutral of
other equipment or lines without leakage protectors. Line N is shared and is not allowed to
be connected to the protective neutral line PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth. That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Introduction and principle analysis of switching regulated power supply
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- A novel and practical DC low voltage stabilized power supply
- CNC regulated power supply production
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- LM317T voltage regulation adjustable circuit diagram explanation
- strain sensor
- Self-defense anti-riot circuit
- High-efficiency speaker circuit for rural stage
- Fish farming thermostatic control circuit
- Varactor Diode Frequency Modulator
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Power phase sequence display circuit
