Home >
Power Circuits >Power Supply Circuits > Capacitor step-down power supply circuit and capacitor selection and precautions
Source: InternetPublisher:拳制龙 Updated: 2011/04/11
Among commonly used low-voltage power supplies, compared with using a transformer to reduce voltage using a capacitor (actually capacitor current limiting), the power supply using a capacitor to step down the voltage is small, economical, reliable, and highly efficient. The disadvantage is that it is not as safe as a power supply transformed by a transformer. AC power is introduced into the load through the capacitor, and there is a voltage of 220V to the ground. People are prone to electric shock. However, if it is used in the internal circuit power supply that does not require human contact, this weakness can be overcome. Power supplies such as refrigerator electronic thermostats or remote control power switches are made by using capacitors to step down the voltage. Compared with resistor voltage reduction, for the lower frequency 50Hz AC, the heat energy loss generated on the capacitor is very small, so capacitor voltage reduction is better than resistor voltage reduction. The size of the current passing through the capacitor is affected by the capacitive reactance of the capacitor Xc=1╱(2πfC). The unit of Xc is ohms; the unit of AC frequency f is Hertz; the unit of capacitor C is Farad.
When capacitors C (as shown in Figure 1) with different capacities are connected to an AC 220V 50Hz AC circuit, the capacitive reactance of C and the current it can pass are as listed in the attached table. This current is the maximum current value that capacitor C can provide. Capacitance (uF) 0.33 0.39 0.47 0.56 0.68 0.82 1.0 1.2 1.5 1.8 2.2 2.7 Capacitance (kΩ) 9.7 8.2 6.8 5.7 4.7 3.9 3.2 2.7 2.1 1.8 1.4 1.2 Current (mA) 2 3 27 32 39 47 56 69 81 105 122 157 183 When using capacitors to step down the voltage to make a power supply, you must pay attention to the following points: (1) After the capacitor steps down the voltage, it must be rectified, filtered and stabilized by a Zener diode as shown in Figure 2 before a stable voltage power supply can be obtained (Note: The rectifier circuit can also use half-wave rectification). (2) The withstand voltage of the capacitor is preferably above 630V, and non-polar capacitors should be used. Polarized capacitors cannot be used. (3) Connect a 500K-1M bleeder resistor in parallel to both ends of the capacitor. (4) If you need to add a power switch, in order to prevent the surge current from flowing in parallel to the load RL, as shown in Figure 3. (5) During the assembly and debugging process, a 1:1 isolation transformer must be used to connect to the AC220V circuit to prevent electric shock. Originally published in "Electronic News" in 2003 by Hebei Gu Xingsheng
![电容降压式电源电路及电容器的选用及注意事项](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/64cceb5c-3c63-11ec-b5a9-086126841eb8.gif)
Latest Power Circuits Circuits
- Energy-saving motorcycle rectifier regulator
- Driving circuit that controls LED brightness using PWM signal
- The constant current source composed of two transistors can drive high power
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- Power supply circuit that can reduce LM317 ripple
- CNC regulated power supply production
- 3~15V 10A adjustable voltage regulated power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
