Image sensor interface circuit diagram based on video surveillance system
Source: InternetPublisher:走马观花 Keywords: Image sensor video surveillance system interface circuit diagram OV9650 Updated: 2020/01/17
Circuit principle: The interface between OV9650 and the processor includes three parts: SCCB interface, data output interface and control interface. The SCCB interface plays the role of transmitting the initialization OV9650 internal register parameters provided by the processor. Its data line SIOD and clock line SI-OC are equivalent to SDA and SCL in the I2C bus. In other words, SC-CB functions as an I2C bus. OV9650 is the slave device of the I2C bus, and S3C2440 is the corresponding master device. The I2 C bus uses serial mode to transmit byte data from high bit to low bit. After each byte is transmitted, the main controller sets SDA to high level and releases it, waiting for the slave device to send a confirmation signal. OV9650 has a built-in 10-bit A/D converter, corresponding to 10 data output ports D[0: 9]. The format of the output image data can be 10-bit raw RAW, RGB or 8-bit RGB/YCbCr converted by internal DSP. The CAM IF unit of the microprocessor chip S3C2440 selected for this system supports the 8-bit YU V/YCbCr format, so the data interface D[9: 2] of OV9650 needs to be connected to the data port CAMDAT A[7: 0] of the CAM IF. connect. The XVCLK of OV9650 is used to receive the 24 MHz working clock output by the CPU. Three clock signals, including the frame synchronization signal VSYNC, the horizontal synchronization signal HREF, and the pixel clock signal PCLK generated internally by the OV9650, are transmitted to the ARM chip for controlling image acquisition. Each VSYN C pulse indicates the beginning of a frame of image data acquisition. The high level of HREF indicates the acquisition of a line of image data. The image sensor collects one byte of data in sequence from left to right during each PCLK pulse. Until all the image data of one frame is collected. The camera uses the CAM130 module, and the image sensor is OV9650 . The schematic diagram and interface circuit of this part are shown in the figure below.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Which one is better, NPN or PNP transistor?
- In-depth analysis of energy losses in oscillation frequencies
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Analysis of the working principle of CMOS/CCD image sensor
- How to calculate the value of capacitors in parallel?
- Build a musical fountain using Arduino and sound sensor
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- FL52C4 induction electronic greeter
- Video surveillance system terminal circuit diagram
- Application of CCD image sensor in low-light TV system
- Relay interface circuit diagram of amateur wireless transceiver
- Telephone sound interface circuit diagram
- fsk modulation and power line interface circuit diagram
- Image sensor circuit diagram
- Optical fiber interface circuit diagram
- MOS image sensor oscilloscope imaging circuit
- Automatic recording telephone interface circuit diagram
- LCD scanning interface conversion VGA interface circuit diagram
