fsk modulation and power line interface circuit diagram
Source: InternetPublisher:同住地球村 Keywords: Interface circuit diagram power line FSK modulation Updated: 2021/03/08
The circuit modulates , amplifies , transmits and isolates high voltage serially encoded control signals . The 556 time base circuit and R1, R2, C1 and R3, R4, C2 form two astable multivibrators respectively, generating two signals, 100kHz and 90kHz. The serial control signal controls the analog switch CC4066. When the level is high, 556 pin 5 outputs 100kHz harmonics to the VT1 resonant amplifier and T, CX1, CX2 for isolation and coupling to the power line . T1 and C8 form a frequency selection circuit, and T, CX1 and CX2 form a high-voltage isolation circuit. When the serial signal is low level, 556 pin 9 outputs 90kHz harmonics to VT2, which is coupled to the power line through resonance amplification and T, CX1, and CX2 isolation. This circuit can utilize the power line carrier channel to transmit control signals .
ck="window.open(this.src)" alt="Click to see larger image"/>
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- Homemade FM wireless microphone for teaching
- Design and Analysis of Half-duplex Intercom Circuit Using LM386
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- RF2942 I/Q 915 MHz Transmitter
- Radio coding transmission circuit composed of MICRF102 and PT2262
- Eight-way remote control transmitter circuit using CS901
- RXM-433/418/315-LC-S Series Receiver Modules
- nRF401/nRF403433/315 MHz Transceiver
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- LCD universal interface circuit design
- Face recognition attendance machine interface circuit diagram
- USB communication circuit
- Relay interface circuit diagram of amateur wireless transceiver
- Telephone sound interface circuit diagram
- Interface circuit diagram using black and white TV as display terminal
- Two-way communication circuit circuit diagram
- Power line transmission temperature patrol detection (transmission) circuit
- Long distance serial communication circuit
- LCD scanning interface conversion VGA interface circuit diagram
