Homemade temporary 220V inverter power supply
Source: InternetPublisher:smallembedded Updated: 2018/04/23
1. Circuit Principle The transistor V, the N1 and N2 windings of the transformer T and the capacitor C form a transformer coupled LC oscillation circuit. Potentiometer RP and resistor R provide bias current for the oscillation tube.
2. Component selection: V uses 3DD59A, R uses a 1/4W ordinary resistor, C uses 0.22μF/50V, the transformer needs to be homemade, N1 and N2 windings use ?0.9mm enameled wire, N3 winding uses ?0.67mm enameled wire, the winding The frame can be made of 1mm thick cardboard. The magnetic core is preferably ferrite U-shaped or ring-shaped. If not, use ordinary E-type or F-type silicon steel sheets instead. Use a 6V battery for the DC current G. 3. Installation requirements As long as the components are in good condition and the installation is correct, it can be debugged. After powering on, adjusting RP can control the output power of the circuit. If the circuit does not vibrate, it may be a problem with the polarity of the feedback winding. Use the polarity identification method to identify it or reversely connect winding N1 or N2 and try again. The terminal with the "·" mark in the figure is the terminal with the same name. When the power grid fails, this circuit outputs alternating current with a frequency of 50Hz and a voltage of 220V±5% to ensure temporary power supply to electrical equipment.
![自制临时220V逆变电源](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/672e63e8-3c63-11ec-a797-086126841eb8.jpg)
Latest Power Circuits Circuits
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How about the boost converter TPS61299?
- Schematic diagram of car cigarette lighter to USB power port
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic circuit description of adjustable voltage regulator LM317
- Recommended circuits for different power on times of LM4911
- Principles and precautions of active discharge circuit
- USB power socket using the car battery
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
