ZC-2-10A automatic charger circuit
Source: InternetPublisher:同住地球村 Updated: 2014/10/02
Single-junction transistor BT33, C3, W1, W2 and other components form a relaxation oscillator. The pulse signal generated by it is sent to the control electrode of silicon controlled thyristor SCR1 through the isolation diode D4. Adjusting the resistance of W1 can change the trigger conduction of SCR1. Angle, that is, changing the charging current. Silicon controlled thyristor SCR2, relay J, W3, W4, D5 and other components form an automatic protection circuit when the battery is fully charged. When the voltage at both ends of the battery is charged to the upper limit set by W3 and W4, D5 is turned on and SCR2 is triggered. Pass, LED2 displays, the relay is closed, and J is switched to normally open at the same time, cutting off the control pulse concentration of SCR1, that is, stopping charging the battery. K2 is a switch for charging 12V and 24V batteries. The picture shows the switch in the 12V position.
Latest Power Circuits Circuits
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- Practical and convenient fax machine power supply control circuit
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- A low-cost, high-reliability battery charger for electric vehicles
- Detailed explanation of mobile phone charger circuit diagram
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
