transistor delay circuit circuit
Source: InternetPublisher:smallembedded Updated: 2012/11/14
The delay circuit introduced here has a delay time that is continuously adjustable from 0 to 120 minutes and can be used as a delay device for household appliances. This circuit has a simple structure and reliable operation, and can fully meet the needs of general household use. Working principle: The delay part is composed of BG1, BG2 and capacitor C to form a Miller integrating circuit. Before the power is turned on, the terminal voltage of C is zero. After the power is turned on, BG3 and BG4 are turned on, and the relay J is closed. At the same time, the capacitor C is charged. The charging current forms a loop through R2, C, and R. The potential of point a rises, causing b The potential at point A decreases, and the decrease in potential at point B limits the increase in potential at point A. As a result of the mutual compensation of the potentials of points a and b, the increase in the potential of point a is very small, and the charging current is nearly constant. When the potential at point b rises to about 10V, BG3 and BG4 are close to cutoff, relay J is released, and the delay process ends. Press the button AN, the capacitor C will quickly discharge through D1, the relay J will close, and the next delay process will begin.
![晶体管延时电路电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/68034338-3c63-11ec-82a3-086126841eb8.jpg)
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Tutorial for building a remote-controlled Arduino Air-Boat
- What is a RADAX motor?
- Motor automatic cycle control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Design and production of radio remote control fan stepless speed regulator
- Design and production of wireless multi-location control switch circuit
- Do-it-yourself trial production of phase failure protection device
- Homemade anti-theft watchdog
- Car audio system anti-theft circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
