Electricity meter no-load energy saver circuit diagram
Source: InternetPublisher:D先生 Keywords: electricity meter energy saver Updated: 2020/07/24
The working principle of the application circuit of this device is shown in the figure. In the watt-hour meter, the voltage coil and current coil are connected to the power grid in parallel. Regardless of whether there is a load in the circuit, the voltage coil is always connected. The CE module can connect the current to the power grid. The problem of empty consumption of the meter is completely solved. When the load RL is connected in series to the current coil circuit, the voltage coil is immediately turned on without affecting the electricity metering; when the load RL is disconnected, the current in the voltage coil is also cut off, so that There is no-load loss.
- Satellite TV room-to-room reception
- Transistor Headphone Amplifier
- A cheap and practical quick checker for Chinese zodiac signs
- LED digital clock language time reporting circuit
- Galanz WP700 mechanical microwave oven circuit diagram
- Transformer AC contactor DC operation circuit c
- Color TV adds AV output socket
- Transformer AC contactor DC operation circuit a
- Fujiba W-8511 computerized microwave oven circuit diagram
- AM radio automatic search and trigger circuit
- Electricity meter no-load energy saver circuit diagram
- The DC watt-hour meter passes through the energized negative connection method
- One way to connect DC watt-hour meter
- Three-phase reactive power meter with two-element sine meter wiring with 60-degree phase angle difference
- DX8 type 100V, 5A universal mutual inductance three-phase three-wire 60 degree reactive power meter wiring
- DT8 type 40-80A direct access electric meter wiring
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- DD17 single-phase jump-in electricity meter wiring
- A method for wiring the active power meter for measuring single-phase electrical appliances
- 220V 25A single-phase electricity meter circuit
