Transistor Headphone Amplifier
Source: InternetPublisher:傻阿乐 Keywords: Headphone Amplifier Updated: 2024/10/18
Here is a low-cost stereo amplifier for driving low-impedance headphone devices. The circuit is shown in the attached figure. The circuit uses several commonly used transistors (BC547, BC557) and passive components such as resistors, diodes and capacitors. In order to drive the headphones, the circuit uses a first-stage preamplifier and a push-pull circuit composed of NPN and PNP.
The stereo preamplifier is composed of transistors T1 and T6. They are used to supply input signals for the left and right channels respectively. The amplified left channel input signal is fed into the push-pull stage composed of transistors T2 and T3 to drive the left channel headphone. Similarly, the amplified right channel input signal is fed into the push-pull stage composed of transistors T4 and T5 to drive the right channel headphone.
When the circuit is powered by +6V to +12V, its output voltage can reach 100 to 200mV. Due to the low power consumption of the circuit, it can also be powered by a +9V PP3 battery.
Install the circuit on a PCB and put it into a suitable small box. Stereo headphones can be purchased from the electronics market.
Components should be carefully soldered on the PCB to avoid cold soldering. After the circuit is installed and soldered, a +9V PP3 battery can be used, and the circuit is now ready for use. In the case of AC power, any common voltage regulator (+6~+12v100mA) can be used to power the circuit.
- Change the Zhongjiu receiver to 12V power supply
- DIY a portable Bluetooth speaker
- Integrated AM and FM radio circuits for household appliances
- Zhongyi brand BCD-215 refrigerator circuit
- Northern brand BD-90 refrigerator circuit
- SH-2 computerized rice cooker circuit diagram
- Broadband high frequency amplifier
- Universal inverter deceleration braking circuit
- Use LB1405 LB1415 as volume meter application circuit
- Refrigerator shell live alarm circuit
- NE5532 designed HIFI headphone amplifier circuit diagram
- Keyed volume headphone amplifier
- Headphone Amplifier
- Convert an idle VCD machine microphone preamplifier into a headphone amplifier
- Typical circuit diagram of LM4921 for two-channel headphone amplifier
- NE5532 high-fidelity stereo headphone amplifier circuit diagram
- ECC822 tube headphone amplifier circuit diagram
- transistor headphone amplifier
- Car voice cell phone call reminder circuit diagram
- Car mobile phone charger circuit diagram
