Circuit diagram for turning off the TV using a reed switch to eliminate the bright spot
Source: InternetPublisher:清宁时光 Keywords: reed switch buffer point Updated: 2021/05/07
The picture shows a reed switch dimming circuit for turning off a television. A reed switch is connected in series to the ground end of the brightness potentiometer W. When the TV is watched normally, the contacts of the reed switch are closed and the charging voltage of the capacitor C is about 160V. When shutting down, the reed switch contact is disconnected. Since the capacity of C is large and its main discharge branch has been cut off, the cathode voltage of the picture tube will be retained for a period of time to cut off the electron beam and achieve the purpose of extinction point. A coil should be wound around the outside of the reed switch. The coil should be tightly wound with 5200 turns on the inner frame with 0.1MM enameled. One end of the coil should be grounded and the other end should be connected to the power supply +12V.
- S-Video/PAL Video Converter
- Change the Zhongjiu receiver to 12V power supply
- cooking timer circuit
- Zhongyi brand BCD-215 refrigerator circuit
- Minsk brand MNHCK-22 refrigerator circuit
- Galanz WP750B computerized microwave oven circuit diagram
- Design of 99-second microcontroller stopwatch
- Color TV adds AV output socket
- small hearing aid
- Using AN5132 as an image intermediate amplifier circuit for color TV sets
- Circuit diagram for turning off the TV using a reed switch to eliminate the bright spot
- Car voice cell phone call reminder circuit diagram
- Car mobile phone charger circuit diagram
- Practical circuit diagram that enables remote wake-up/shutdown
- Cell phone detector circuit diagram
- Key debounce circuit diagram
- Philips shaver circuit diagram
- Design and production circuit diagram of wireless FM microphone
- AD7780 electronic scale circuit diagram
- Illustration of the design principles and applications of mobile phone radio frequency circuits
