Car mobile phone charger circuit diagram
Source: InternetPublisher:aytwartoofyoroo Keywords: charger mobile phone charger mobile phone circuit Updated: 2021/08/07
Remove the shell of an abandoned but still usable mobile phone charger, remove the original 220V voltage through the capacitor step-down and diode rectifier, and connect the 12V car plug of the cigarette lighter in the car with the 12V input terminal in the picture. Connect, and then measure whether the voltage at the output terminal corresponds to the charging voltage of the mobile phone, 4.2~5V. If it is normal, just fix the charger in a place out of the way. Pay attention to isolation around the installation part to prevent short circuit.
If the output voltage is slightly lower than the user's mobile phone charging voltage, the optocoupler current limiting potentiometer RP needs to be adjusted appropriately so that a suitable charging voltage can be obtained.
- Ultrasonic atomization principle diagram
- Share a home telephone recorder circuit diagram
- Double tuned amplifiera
- Circuit diagram of Rongsheng CFXB1, 3 and 4 double lamp thermal insulation automatic rice cooker
- Tube amplifier CS8412+PCM63 classic design (power supply part) circuit diagram
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- Universal inverter deceleration braking circuit
- Delta VFD-P inverter typical application circuit
- Monolithic integrated circuit radio
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- How to ensure that the power supply works for a long time—PA power analyzer
- Electric fence charger circuit diagram
- Battery charging circuit with reverse connection display a
- Mobile phone charger circuit 2
- Charger circuit designed by lm358
- Voltage detection relay for battery pack charger
- Constant current charger with short circuit and polarity protection
- Constant voltage and current limiting charger
- Automatic parallel charger
- Charger using switching constant current circuit
