315M remote control circuit design
Source: InternetPublisher:风向双子座 Updated: 2012/03/28
Although OOK modulation has poor performance, its circuit is simple and easy to implement and its operation is stable, so it has been widely used. It is almost without exception used in automobile and motorcycle alarms, warehouse doors, and home security systems. circuit. Early transmitters mostly used LC oscillators, which caused serious frequency drift. The emergence of surface acoustic devices has solved this problem. Its frequency stability is roughly the same as that of crystal oscillators, and its fundamental frequency can reach hundreds of megahertz or even gigahertz. There is no need for frequency multiplication, and the circuit is extremely simple compared to a crystal oscillator. The following two circuits are common transmitter circuits. Due to the use of acoustic surface devices, the circuit works very stably. Even if the antenna, acoustic surface or other parts of the circuit are held by hand, the transmitting frequency will not drift. Compared with Figure 1, the transmit power of Figure 2 is larger. It can reach more than 200 meters.
Figure 1
Figure 2 The receiver can use a super regenerative circuit or a superheterodyne circuit. The super regenerative circuit has low cost and low power consumption of about 100uA. The well-adjusted super regenerative circuit sensitivity and first-level high amplification, first-level oscillation, and first-level Mixers and two-stage mid-amp superheterodyne receivers are similar. However, the super-regenerative circuit has poor operating stability and poor selectivity, thus reducing its anti-interference ability. The figure below shows a typical super regenerative receiver circuit.
The sensitivity and selectivity of superheterodyne circuits can be very good. The monolithic integrated circuit launched by the American company Micrel can complete reception and demodulation. Its MICRF002 is an improved version of MICRF001. Compared with MICRF001, it has lower power consumption. And has a power shutdown control terminal. MICRF002 has stable performance and is very easy to use. Compared with super reproduction circuits, the disadvantage is that the cost is relatively high (RMB35 yuan). The following is its pin arrangement and recommended circuit.
ICRF002 uses ceramic resonators. By using different resonators, the receiving frequency can cover 300-440MHz. MICRF002 has two working modes: scanning mode and fixed mode. The scan mode acceptance bandwidth can reach several hundred KHz. This mode is mainly used with LC oscillation transmitters because the frequency drift of LC transmitters is large. In scan mode, the data communication rate is 2.5KBytes per second. The bandwidth of the fixed mode is only tens of KHz. This mode is used with transmitters that use crystal oscillator frequency stabilization, and the data rate can reach 10KBytes per second. The working mode selection is realized through pin 16 (SWEN) of MICRF002. In addition, use the wake-up function to wake up the decoder or CPU to minimize power consumption. MICRF002 is a complete single-chip superheterodyne receiving circuit, which basically realizes "direct data output" after "antenna input". The receiving distance is generally 200 meters.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/92f8e69e-3c63-11ec-846f-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/92f982e2-3c63-11ec-8a87-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/92f9f814-3c63-11ec-b612-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/92fa4636-3c63-11ec-b796-086126841eb8.gif)
Latest Control Circuits Circuits
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Peripheral circuit of automotive motor controller power supply chip
- A simple door handle touch alarm circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- A small improvement to the temperature and water level indicator alarm
- Squirrel cage asynchronous motor reverse braking control circuit
- Add one more component to improve the phase failure protection function
- Design and analysis of wire control circuit
- Design and analysis of a four-bit remote control component capable of remote reset
- Simple three-phase motor phase loss protection circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
