An example of LM317T application circuit
Source: InternetPublisher:太白金星 Updated: 2010/07/11
When using LM317T to make an adjustable regulated power supply, poor contact of the potentiometer often causes the output voltage to rise and burn the load. If a transistor is added (as shown in the figure below), under normal circumstances, the base potential of T1 is 0 and T1 is turned off, which has no effect on the circuit; but when W1 has poor contact, the base potential of T1 rises. When it rises to At 0.7V, T1 is turned on, which reduces the voltage of the adjustment terminal of LM317T and the output voltage, thus protecting the load. If the transistor is removed and the center point of W1 is disconnected, the 3.8V small bead will be burned immediately, and the measured output voltage is as high as 21V. When T1 is added, the brightness of the small beads decreases. At this time, the output voltage of LM317T is only 2V, thus effectively protecting the load.
![LM317T应用电路一例](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d14e3c08-3c63-11ec-a0e3-086126841eb8.jpg)
Latest Power Circuits Circuits
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Recommended circuits for different power on times of LM4911
- Transformerless AC-DC constant current LED driver circuit
- LED Driver ZD1680
- Switching power supply circuit composition and function introduction of each part
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage regulated power supply circuit
- LM317T voltage regulation adjustable circuit diagram explanation
- Circuit diagram explanation: simple switching power supply circuit diagram
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
