Overvoltage and overcurrent protector
Source: InternetPublisher:难得正经 Updated: 2018/12/14
When the power supply voltage or the current drawn by the load is too large, the circuit in the figure below can disconnect the load and give a fault indication.
During normal operation, both Tr1 and Tr2 are cut off, 555 is reset, and the discharge transistor in 555 is turned on. It draws current from the base of Tr3, causing Tr3 to open to saturation, and the power supply 5~12V is directly sent to the main load. When the current drawn by the load exceeds the specified value, the voltage drop on Rsc increases, causing Tr1 to turn on, and 555 is triggered, so the internal discharge transistor is cut off, followed by Tr3, which is also cut off to isolate the power supply from the load. At this time, 555 is in a monostable state. Once the stabilization time is up, as long as the load overcurrent is not eliminated, 555 is triggered again, and Tr3 continues to isolate the load. If there is overvoltage in the load, Tr2 will be turned on after R4, R5, and D1, which will also trigger the 555. Tr3 will also isolate the load at this time. For overcurrent or overvoltage, pin 555③ will output a high potential, causing the LED to light up, indicating that the load is in an isolation state. Since Tr3 is either in saturation or cut-off, only one power transistor can work.
![过压过流保护器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1d5e494-3c63-11ec-82a5-086126841eb8.jpg)
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How can we make the robot move precisely on a predefined path?
- Add one more component to improve the phase failure protection function
- Design and analysis of wire control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of voice control circuit
- Audio interface protection circuit
- An experimental model of an infrared radio alarm
- Night dog barking anti-theft reminder circuit
- "Watchdog" anti-theft alarm circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
