Home >
Power Circuits >Linear Regulated Power Pupply > Three-terminal voltage regulator current expansion circuit
Source: InternetPublisher:两手空空 Updated: 2011/02/26
[url=../Upload/2005527171649144.jpg] When the load current is greater than the nominal current value of the three-terminal adjustable integrated voltage regulator, current expansion can be used to solve the problem.
The circuit shown in Figure 1 uses a PNP high-power tube to expand the current. A 3AD53 high-power tube can expand the current to 6A. When one is not enough, two or more high-power tubes can be connected in parallel, such as It can be expanded to 18A with three.
The circuit shown in Figure 2 is an example of using NPN high-power tubes to expand current. At this time, a 3DD15 can provide a load current of 5A, an LM317 can provide a current of 1.5A, and the output terminal can provide approximately 6.5A current. At this time, two diodes play an isolation role, and two or more high-power tubes can be connected in parallel to expand the current to a larger value. When the nominal current of the LM regulator is 0.1A and the load current needs to be very large, the current expansion method is: LM317 can first drive a smaller power tube, and then use a smaller power tube to The tube drives one or more more powerful tubes.
In the circuit shown in Figure 3, LM317 first drives BG1-3DDl5, and then GB1 drives BG2 and BG3 - two 3DDl70 tubes. At this time, the voltage regulator can output a current of 20A.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1f3f454-3c63-11ec-8a42-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1f46986-3c63-11ec-b0a0-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1f4b7a6-3c63-11ec-9dab-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1f505c8-3c63-11ec-be79-086126841eb8.gif)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1f57afa-3c63-11ec-b15c-086126841eb8.gif)
Latest Power Circuits Circuits
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- A very convenient small power supply circuit to share
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Introduction and principle analysis of switching regulated power supply
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Simple and practical LED lamp driving circuit
- Dual forward converter schematic diagram
- Adjustable voltage power socket
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
