Power polarity tester
Source: InternetPublisher:太白金星 Updated: 2018/12/07
This circuit can detect the positive and negative polarity of 3V-30V power supply and indicate it with LED. The test circuit is a constant current source. When the polarity of the input power supply under test is correct, T1 is turned on, T2 is also turned on, and the LED emits light. The action of diode D2 keeps the base voltage of T2 constant. In this way, no matter how large the conduction current of T1 is, T2 sends out basically a constant current. If the polarity of the power supply under test is reversed, diode D1 will conduct, and as a result, T1 and T2 will both cut off, the LED will go out, and switch S1 can connect the LED to the internal circuit for self-test.
![电源极性测试器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d229840c-3c63-11ec-982f-086126841eb8.jpg)
Latest Detection Circuits Circuits
- Lightweight and practical multi-core cable detection circuit
- Temperature Range Monitoring System
- Homemade refrigerator monitor
- Digital electronic thermometer using semiconductor diode as temperature sensor
- NE555 makes a simple and practical acupoint detector
- TC02 temperature measurement circuit
- Circuit Fault Tracker
- 5 tone detector circuit diagram
- AC ammeter circuit
- Digitally controlled operational amplifier gain circuit
Popular Circuits
- LED lighting display detection circuit with overload protection
- Paper thickness detection circuit
- Pyrothermal infrared detection circuit composed of OPA111
- Simple infrared detection circuit
- Level detection circuit using digital-to-analog converter
- A5348 smoke alarm detection circuit - block diagram
- Photodetection circuit for DC recovery to suppress unwanted stable background light
- Differential light detection circuit
- Film thickness detection circuit using eddy current method
- Thin object presence/absence detection circuit
