Home >
Power Circuits >Power Supply Circuits > Two-way mains automatic conversion power supply device
Source: InternetPublisher:toothache Updated: 2019/08/28
Two-way power supply devices generally have manual switching control. However, due to the harsh climate in the mountains, power outages occur from time to time, and the personnel on duty are more than 100 meters away from the power supply room. When a certain power supply is suddenly stopped, manual power outage takes a long time and the labor intensity is high. Large, the TV transmitter and three sets of FM radio transmitters in the computer room were stopped, affecting the broadcast. This automatic power swapping device can automatically switch the power supply within 1/10s when a certain mains power supply suddenly fails, so that the normal broadcast quality is not affected. The entire device cooperates with the power voltage stabilizer (250KVA). Only two 200A AC contactors are needed on the original switchboard. The economic benefits are obvious. After the device is adopted, the power supply and broadcast quality of the computer room are greatly improved. 1. When the power supply starts, the three-phase knife switch KM opens and KP closes. The normally closed contact of the AC contactor CJM energizes the AC contactor CJP. The main contact CJP1 closes and is powered by external power 1. At this time, the normally closed contact of CJP Contact CJP2 is disconnected, then closed KM, external power 2 is waiting. 2. When the external power supply 1 suddenly loses power, CJP loses power, its main contact CJP1 is open, the auxiliary contact CJP2 is closed, CJM is powered, the main contact CJM1 is closed, and is powered by the external power 2. At this time, the normally closed contact CJM2 is open On, wait after external power 1 is restored. 3. When manual power supply conversion requires a certain mains supply, you only need to open the other switch, and external power 1 and external power 2 are manually switched. 4.KP and KM are 600A three-phase knife switches, and CJP and CJM are 200A AC contactors.
![两路市电自动转换供电装置](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d2537ada-3c63-11ec-b40f-086126841eb8.jpg)
Latest Power Circuits Circuits
- How about the boost converter TPS61299?
- How to Make a Soft Latch Circuit
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Current/voltage conversion circuit using current converter
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Power supply circuit that can reduce LM317 ripple
- UC3842 Electric Vehicle Charger
- Mc34063 MP3 Switching Charger
- Detailed explanation of mobile phone charger circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
