Simple phase sequence indicator
Source: InternetPublisher:常思一二 Updated: 2013/12/06
As shown below. When using it, you only need to connect the three wires X, Y, and Z to the three-phase circuit, and the phase sequence of the three-phase alternating current can be easily identified by turning off and on the neon tube. If the neon tube lights up, then X, Y, and Z are connected to phases A, C, and B of the power supply respectively. On the contrary, if the neon tube does not light up, then X, Y, and Z are connected to phases A, B, and C of the power supply respectively. The resistor in the circuit can be a 1/8W carbon film resistor, and the capacitor must have a withstand voltage greater than 400V. Neon tubes can be used as neon tubes in fluorescent lamp starters.
![简易相序指示器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d25c549c-3c63-11ec-82e3-086126841eb8.jpg)
Latest Detection Circuits Circuits
- How to measure short circuit and ground with a multimeter
- Make a Economical and Practical Rectifier Voltmeter
- Simple and practical motor short circuit tester
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Four logic probe circuit diagrams
- Homemade Metal Detector
- 1.5V and 9V battery tester circuit diagram
- direct coupled amplifier circuit
- DC power meter
- voltage amplifier circuit
Popular Circuits
- LED lighting display detection circuit with overload protection
- Paper thickness detection circuit
- Pyrothermal infrared detection circuit composed of OPA111
- Simple infrared detection circuit
- Level detection circuit using digital-to-analog converter
- A5348 smoke alarm detection circuit - block diagram
- Photodetection circuit for DC recovery to suppress unwanted stable background light
- Differential light detection circuit
- Film thickness detection circuit using eddy current method
- Thin object presence/absence detection circuit
