Home >
Power Circuits >Switching Regulated Power Supply > 4W backup switching regulated power supply
Source: InternetPublisher:通通 Updated: 2015/03/30
The circuit of the +5V, +12V dual output 4W backup switching regulated power supply composed of TOP221P is shown in the figure. The circuit uses one piece each of TOP221P (ICl) and optocoupler PC817A (IC2). This circuit can continue to supply power after the main power supply is cut off, ensuring that the data in the CPU and real-time calendar clock chip internal RAM of the instrument will not be lost, and can also maintain the working status of the remote control port for a period of time. The input terminal is connected to the DC voltage Ui. The Ui value should depend on the variation range of the AC input voltage u (such as 85" 245V). T is the high-frequency transformer, N1 is the primary coil, N2 is the secondary coil (also known as the output coil), and N3 is the feedback coil. As shown in the figure The black dots represent the same terminal of each coil, also known as the non-inverting terminal. The isolated +5V output is designed to power circuits that require electrical protection, while the non-isolated +12V output can power the PWM controller of the main power supply. In standby mode; once a call is received, the main power supply immediately switches to the normal working state. RTN in the figure is the return terminal (RETURN) of the +5V output, which is the common/ground terminal.
This circuit is a single-ended flyback switching regulated power supply. The so-called single-ended means that TOP221P has only one pulse width modulation signal power output terminal - drain D. The flyback type means that when the power switch MOSFET is turned on, the electric energy is stored in the primary coil of the high-frequency transformer; When the MOSFET is turned off, electric energy is output to the secondary. Since the switching frequency is as high as 100kHz, the high-frequency transformer can quickly store and release energy, and continuous output can be obtained after high-frequency rectification and filtering.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e8a1f358-3c63-11ec-b324-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e8a28f9a-3c63-11ec-b815-086126841eb8.jpg)
Latest Power Circuits Circuits
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How to Make a Soft Latch Circuit
- In-depth analysis of DC-AC converter inverter
- Detailed explanation of 5v charger circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- A simple positive and negative power supply circuit
- Converting a lithium battery charging board into a constant voltage and current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade Electric Bike Fast Charger
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
