Home >
Power Circuits >Switching Regulated Power Supply > 15V/6A, 90W switching regulated power supply
Source: InternetPublisher:宋元浩 Updated: 2015/08/07
The circuit of a 15V/6A, 90W switching power supply composed of MC33374 is shown in the figure. Using the E28 ferrite core, the wire diameters of the primary coil and feedback coil remain unchanged, and the number of turns should be 34 and 4 turns respectively. The secondary coil is made of double φ0.8mm enameled wire and wound with 5 turns. The air gap of the magnetic core is 0.56mm. The measured technical specifications of this power supply are shown in the following table. The measured technical specifications of this power supply are shown in the following table. The
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e9364646-3c63-11ec-8663-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e93730a6-3c63-11ec-962a-086126841eb8.jpg)
Latest Power Circuits Circuits
- How about the boost converter TPS61299?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- Benefits of Wide Bandgap Technology for Power Converters
- Recommended circuits for different power on times of LM4911
- A simple positive and negative power supply circuit
- An ultra-low output voltage regulator
- Power supply circuit that can reduce LM317 ripple
- 0.7~24V continuously adjustable current limiting power supply
- Electric bicycle battery charger circuit
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
