How to use bidirectional DCDC converter in elevator automatic rescue device to improve efficiency and reduce costs
Source: InternetPublisher:武林萌主 Keywords: DCDC power supply design Updated: 2020/12/10
1 Introduction
Since elevators transport millions of people every day, operational safety is critical. Have you ever wondered what happens when the main power to an elevator is turned off? Will the lift descend onto the lift rails, or will it get stuck somewhere between the landing doors? To prevent the first consequence, a fail-safe braking mechanism ensures that the elevator car stops immediately when the main power supply is switched off. After a stop, in order to prevent people in the elevator from being trapped in the elevator until power is restored, the automatic rescue device ( ARD), also known as the elevator emergency power supply, comes into play.
2. Introduction to automatic rescue device ( ARD)
ARD is a backup power device that continuously monitors the main elevator power supply. Unexpected shutdowns can occur due to grid failure or faulty wiring that interrupts the input phases of the elevator drive. The ARD detects such a fault condition, immediately starts supplying power to the elevator drive and sends a fault signal to the elevator controller. The controller then releases the motor-driven brake and slowly brings the car to the nearest landing door. The direction of the car depends on the minimum amount of power required to bring it to the landing door. Once the nearest floor is reached, the elevator doors open and audio/visual indicators indicate it is safe to exit. After a predetermined time, the elevator door closes again and the power to the elevator drive is turned off.
3. Automatic rescue device ( ARD) power supply design
Figure 1 illustrates the connection from a traditional ARD to the elevator system. The three-phase mains supply is connected to the traction drive via a main contactor. The power contactor is interlocked with the ARD contactor, which connects the output of the ARD to the traction drive. The interlock ensures that both contactors do not open at the same time, thereby avoiding a short circuit between the mains and the ARD output. The single-phase output from the mains power supplies the remaining components of the elevator system such as controllers, door motor controls, brakes, and safety chains through contactors. ” This contactor is also interlocked with the ARD’s single-phase output contactor. During normal operation, the ARD charges the backup battery; its inverter output is disconnected from the elevator system.
Figure 1: Traditional ARD system connections in elevators
The ARD system shown in Figure 2 has an AC/DC charger power stage to charge the battery. A DC/DC converter steps up the battery voltage to a high voltage, and a DC/AC inverter produces an AC output that powers the elevator traction drive and elevator controls. Circuitry continuously monitors the AC power input for outages and single-phase conditions and enables or disables the required power stages within the ARD.
Figure 2: Traditional ARD system
Another approach is to use a bidirectional DC/DC converter, as shown in Figure 3 and Figure 4. Energy can be transferred in both directions. In ARD, the converter is connected directly to the DC link of the elevator traction drive. During normal operation, the converter works like a battery charger, charging the battery from the DC link. When there is no mains supply, the converter works like a boost converter, powering the DC link from the battery. Another inverter stage within the ARD generates a single-phase AC voltage for the control unit.
Figure 3: ARD system with bidirectional DC/DC converter connected to the elevator system
Figure 4: ARD with bidirectional DC/DC
Comparing the two approaches, Table 1 shows how the bidirectional DC/DC converter approach provides more benefits.
scope |
Traditional ARD system using uninterruptible power supply (UPS) |
ARD system with bidirectional DC/DC converter |
Converter stages |
three: · AC/DC charger for charging batteries . · A DC/DC converter to boost the battery voltage to a high voltage. · DC / AC inverters that generate AC output for traction drives and elevator control systems. |
two: · AC/DC battery charger and DC/DC boost converter combined in one bidirectional converter. · A DC/AC inverter to generate a single phase output for the elevator control system. The DC/DC converter is eliminated and the inverter is powered directly by the DC bus. |
efficiency |
ineffective: • Losses in the three switching converter stages. · The battery power is converted by the ARD to AC power and then converted back to the DC link voltage by the AC/DC rectifier of the traction drive . |
high efficiency: · Only two switching power stages. · Bidirectional converter connected directly to the DC link of the traction drive. |
cost |
High: · An interlocked contactor ( highlighted with a red box in Figure 1 ) is required to provide AC power to the traction drive and avoid short circuiting the ARD output to the mains supply. · The input and output of ARD require three-phase wiring. · Three converter stages means higher bill of materials (BOM) cost. |
low: · The driving power supply does not require an interlocking contactor because the bidirectional converter output cannot be short-circuited to the main power supply. · The wiring is simpler and is single-phase. · The BOM cost of implementing two converter stages is lower. |
Table 1: Comparison of traditional ARD and ARD with bidirectional DC/DC converter
Typical battery voltages for elevator ARDs are 24 V, 36 V, 48 V and 60 V. The nominal DC link voltage of a three-phase 400 V AC powered elevator traction drive is approximately 600 V. The Isolated Bidirectional DC/DC Converter Reference Design is a 2kW, 48V to 400V digitally controlled bidirectional power stage used as a half-bridge battery charger and reverse current fed full-bridge boost converter. The design is scalable to different power levels and input battery voltages by simply redesigning the transformer and selecting appropriately rated MOSFETs.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Build a simple buck-boost regulator and test it on a breadboard
- Driving circuit of switching power supply field effect tube
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Detailed explanation of 5v charger circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Dual adjustable power circuit
- Commonly used power circuits in printers
- Transistor stabilized current power supply circuit 2
- Timing switch AC power circuit
- CF1 (CF2) DC power supply circuit
- Recording level power supply circuit
- Music power circuit
- ±15V active servo power circuit
- Wide input 350mA LED driver circuit based on NCL30000
- Common power circuits and applications 03
