Dual adjustable power circuit
Source: InternetPublisher:国民男神经 Keywords: Adjustable power supply power circuit MDASH Updated: 2020/04/17
Circuit principle: This circuit uses a three-terminal adjustable integrated voltage regulator. When S is set to 1, the power
supply After bridge rectification, the AC voltage is sent to the inputs of IC1 and 1C2 respectively. terminal, through the control of the sampling resistors Ri, M and the adjusting potentiometers RP1 and RP2,
a continuously adjustable voltage of ±1.25-15V is obtained at the output terminal. When S is set to 2, the dual-group output power transformer T is used as a single group.
After the power supply voltage is rectified and filtered, only IC1 is sent to obtain
a single power supply output of +1. 25-30V. Among them, resistors
Rl, Rz: 240CZ, potentiometers RP1, RP2:
4.7kf2; capacitors cl, C: 3300FcF/150V, G,
C: 0.33_uF/63V.C5, C: lOtlFl50V;
diodes VD1~VD4: 1N4001, VD5~VD6:
1N4001} Three-terminal integrated block ICl: LM317. IC2:
LM337; switch S: KNX (Z×2).
All capacitors in this power supply must have a withstand voltage greater than
50V. The power consumption of the two three-terminal adjustable voltage stabilizing blocks is about
15W. Pay attention to adding sufficient radiators.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- What kind of circuit is a voltage regulator circuit?
- Basic circuit description of adjustable voltage regulator LM317
- Detailed explanation of 5v charger circuit diagram
- Adjustable regulated power supply with current limiting protection
- Production of backup power supply for cordless phone
- Homemade Electric Bike Fast Charger
- STR5412 power circuit
- AD693 functional schematic diagram
- Power circuit a composed of intelligent thyristor modules
- Dual adjustable power circuit
- Temperature control system block diagram
- Power circuit of LBO-522 dual trace oscilloscope
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Lightning protection wiring for 300 to 1500kW direct-match generator b
- Two options for the input part a
- Ten-band frequency equalizer
