Home >
Power Circuits >Other Power Circuits > Overall block diagram of virtual min-controlled sealed lead-acid battery testing system
Source: InternetPublisher:Lemontree Updated: 2011/09/02
The virtual valve-regulated lead-acid battery test system initializes and controls the hardware through application software, and provides a simple interface and data transmission for the monitoring software. The display and management software provides a fully functional graphical interface and can perform virtual valve-controlled lead-acid battery testing. The setting of working control parameters of the acid battery testing system and the data collected from the application software provide various display analysis functions such as charts and curves and historical data management functions. The data acquisition card in the virtual valve-regulated lead-acid battery testing system is the system The data acquisition and storage unit, the data transmission between it and the microcontroller is realized through the USB interface. The following figure is the flow chart of the USB control endpoint read and write circuit.
The flow chart of the data sampling circuit:
Latest Power Circuits Circuits
- How about the boost converter TPS61299?
- Using Lead-acid Battery as Power Source for Walkman
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Visible laser digital control modulation driver
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Constant current LED lamp driver circuit with soft start and anti-shock
- A simple positive and negative power supply circuit
- Car Audio Power Supply
- Practical constant current charger-----Constant current charger
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
