Do you know Nordic nRF52840 multi-protocol SoC?
Source: InternetPublisher:JFET Keywords: nrf52840 Mouser Electronics Updated: 2021/08/15
What is the Nordic nRF52840 multi-protocol SoC? What does it do? Mouser Electronics is stocking Nordic Semiconductor’s nRF52840 multi-protocol system-on-chip (SoC) starting today. The ultra-low power nRF52840 SoC is based on Nordic's nRF52 series architecture and is compatible with Nordic's existing nRF52 series, nRF51 series and nRF24 series products. It is one of the few single-chip solutions on the market that can simultaneously support Bluetooth 5 ( Bluetooth® 5) and Thread, and soon Zigbee® support.
The Nordic nRF52840 SoC, available from Mouser, is based on Nordic's existing nRF52 series SoC architecture and can support complex Bluetooth low energy and other low-power wireless applications. The nRF52840 SoC is powered by a 64MHz 32-bit Arm® Cortex®-M4F processor and a CPU with 1 MB Flash, 256 KB RAM, floating point unit and digital signal processor (DSP). This SoC also integrates the Arm TrustZone CryptoCell-310 cryptographic accelerator for the industry's best security. Compliant with the Bluetooth 5 specification and featuring higher maximum output power, the nRF52840 SoC is a Bluetooth Low Energy wireless connectivity implementation that provides up to four times the range and double the bandwidth compared to Bluetooth 4.2 Bluetooth Low Energy implementations. Raw data bandwidth (2 Mbps). In addition to supporting Bluetooth 5, the nRF52840 SoC also supports NFC-A tags and IEEE 802.15.4 functionality. IEEE 802.15.4 can be used in smart home application technologies based on Zigbee and Thread, and can also be used as a network adaptation layer with 6LoWPAN and standard Internet protocols.
This SoC comes with a companion Nordic nRF52840 preview development kit. This kit contains the nRF52840 SoC onboard as well as four user-programmable buttons and LEDs. The hardware is compatible with Arduino Uno R3-based expansion boards and has features for all inputs and outputs (I/O). ) and connector pins for the interface, including a dedicated connector for an external NFC antenna.
The Nordic nRF52840 multi-protocol SoC is an ideal solution for wireless Internet of Things (IoT) applications such as advanced wearables, virtual reality (VR) and augmented reality (AR) devices, high-performance HID controllers, smart home products, and interconnects Industrial equipment. The above is the analysis of Nordic nRF52840 multi-protocol SoC, I hope it can help you.
- Benefits of Wide Bandgap Technology for Power Converters
- In-depth analysis of DC-AC converter inverter
- Driving circuit of switching power supply field effect tube
- Energy-saving motorcycle rectifier regulator
- Use pulse width modulation to get a precise output voltage
- Transformerless AC-DC constant current LED driver circuit
- LNK304 non-isolated LED light string driver circuit
- Miniature polarity reversal power supply using MAX1721
- A novel and practical DC low voltage stabilized power supply
- Electric bicycle battery charger circuit
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power supply circuit b
- Transistor stabilized current power supply circuit 2
- Timing switch AC power circuit
- Super Class A power amplifier power circuit
- Common power circuits and applications 05
- ±5V, ±12V power circuit B
- COMPAQ 420G type SVGA color display power supply circuit
