Adaptive zero-voltage switching electronic ballast
Source: InternetPublisher:常思一二 Updated: 2016/07/05
Relevant key device information applied in this article:
IR2520
IRFC420
adaptive zero-voltage switching electronic ballast schematic diagram
IR2520 is mainly used to drive fluorescent lamps below 40W. The rated power of the lamp is different, and the component parameters such as Q1, Q2, L2 and C7 are slightly different. For example. When the rated power of the lamp is in the range of 16-28W. Q1 and Q2 should use 500V, 2A MOSFET (such as IRFC420, etc.), the inductance value of L2 is approximately between 1.8mH and 3.5mH, and the capacity of C7 is usually 3.3nF-5.6nF. The greater the power of the lamp, the smaller the inductance value of L2, which is determined through debugging so that the lamp current is close to or consistent with the rated current of the lamp. .
Latest Power Circuits Circuits
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- What kind of circuit is a voltage regulator circuit?
- Transformerless AC-DC constant current LED driver circuit
- Miniature polarity reversal power supply using MAX1721
- Adjustable regulated power supply with current limiting protection
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Converting a lithium battery charging board into a constant voltage and current charger
- How to Select Modular EMI Filters for AC-DC Converters
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
