Starting circuit combining inching and long-term operation
Source: InternetPublisher:已注销 Updated: 2019/03/06
In reality, sometimes it is necessary to manually operate the motor, and the motor needs to be able to run for a long time. The circuit shown in the figure is designed to address this problem. When the start button ST is pressed, the motor M starts normally, the circuit uses its normally open auxiliary contact to self-lock, and the motor M runs for a long time. When STP is pressed, motor M stops. If button SB is pressed, motor M starts. Since the normally open contact of SB is pressed, its normally closed contact is also disconnected. Therefore, after releasing SB, KM loses power and motor M stops. Therefore, this This operating mode is called "jog".
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Peripheral circuit of automotive motor controller power supply chip
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- Simple three-phase motor phase loss protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Precious home appliance anti-theft alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
