Relay control circuit a
Source: InternetPublisher:国民男神经 Keywords: Control circuit relay control BSP Updated: 2020/06/10
Shown is the relay control circuit . There are many switches in the microwave oven. If the switch is turned on, it can provide power, and if the switch is turned off,
it can provide protection. There are many components in a microwave oven that need to be controlled, such as fans, light bulbs, food turntables, timers, etc. Most of the signals controlled by relays
in the circuit are strong signals, and many of them have a voltage of 220 V. If a transistor is used directly to control
the switch, the transistor will have to withstand a high voltage of 220 V, which requires the use of high-voltage-resistant transistors and high-power transistors. This will not only
increase the production cost of the circuit, but also ensure the safety during maintenance. Because the voltage and current of the transistor are high, a heat sink must be added. The
heat sink may be charged, and the three legs of the transistor may also be charged, which is very unsafe. By using relays, low-voltage signals can be used to
control high-voltage signals.
As you can see from the picture, there is a coil made into an electromagnet inside the relay. When the electricity is energized, the electromagnet will move, thereby driving the contacts to open and close
. The voltage on the contacts is isolated from the relay coil, so there will be no high voltage in the circuit controlling the relay coil, which is very safe.
The two circuits on the left and right in the figure have the same structure, but the control transistors used are different. The circuit on the left uses NPN
transistors, and the circuit on the right uses PNP transistors. The polarities of PNP transistors and NPN transistors are different, so in
a circuit using PNP transistors, the voltage must be applied to the emitter of the PNP transistor, and the ground must be connected to the relay end. The driving signal of the house
is also opposite to what was mentioned before (NPN transistor circuit). If the transistor is turned off, the control signal in the circuit is high level, and if the control
signal appears low level. The transistor will turn on, and 12 V will flow through the relay to control the on or off of the relay contacts. If a PNP transistor is connected to the circuit
, the polarity of the designed protection diode must be reversed, because the polarity of the induced electromotive force generated by the coil also changes
. When looking at the circuit diagram, pay attention to the model of the transistor. Different transistor models have different control signals , voltage polarity, and protection diodes
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How do Zener diodes protect circuits?
- Analysis of the working principle of CMOS/CCD image sensor
- What are the classifications of filters?
- What are the parts of the fpga design process
- What is a D flip-flop and how does it work?
- Diode-based clipping circuit
- Causes of PCB deformation How to prevent circuit board bending and warping
- What is the difference between high-side and low-side resistive current sensing
- Digital number selection machine
- Motor overcurrent protection circuit
- electromagnetic field sensor
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Diode square rate detection circuit
- Wireless microphone circuit
- Power phase sequence display circuit
- Small current generator circuit
- Home appliance repair signal generator circuit
