Y-△ main circuit adapted to motors with long starting time
Source: InternetPublisher:偷熊计划 Updated: 2017/04/21
For loads with long startup time, such as centrifugal fans, circulating compressors, ball mills, etc., the Y-△ main circuit should be wired as shown in the figure. The current setting value IFT of the thermal relay FT is approximately 0.58IN. Since the thermal relay is in the starting circuit, the starting current is very large at startup (such as a 37kW motor, rated current IN = 70.2A, starting current up to 163A, thermal relay setting value IFT is 40A), so the FT will act instantly and start fail. If IFT is increased, the thermal relay will lose its overheating and overload protection function in the normal operation of the motor M. Using the connection method shown in the diagram can avoid the above situation.
Latest Control Circuits Circuits
- A simple magnetic switch circuit sharing
- Servo motor pin diagram/working principle/application
- Use your smartphone to turn on/off the power in your home
- Peripheral circuit of automotive motor controller power supply chip
- How to Make a Simple Chicken Incubator
- DIY an electromagnetic levitation device
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Hydraulic control circuit design and analysis
- An experimental model of an infrared radio alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
