One machine and multiple ground water pump control circuit
Source: InternetPublisher:闪电杰克 Updated: 2012/05/28
Many high-power equipment require circulating cooling water for cooling. When there are a large number of equipment that need to be cooled, a shared water pump can be installed and controlled by one machine and multiple places. That is, each operating point can start the pump independently and stop the pump independently. When any one of them is using water, It can also prevent other points from turning off the pump and cutting off water. Now take two control points as an example to illustrate the control principle. The circuit is shown in the figure. The main circuit and main control part are installed in the pump room. The main control circuit is equipped with ST and STP buttons for maintenance and testing. The main control line (pump room) and each use point (control point) are connected by three public control lines (dashed lines in the figure). When you need to add cooling equipment, you only need to extend the public line to the control panel at that point without changing the wiring at other points.
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Build a glove-controlled robotic arm
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Temperature control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
