Home >
Control Circuits >Motor Control > Chunhua brand vacuum cleaner electronic speed control circuit
Source: InternetPublisher:jikai233 Updated: 2017/09/12
The figure shows the electronic speed control circuit of the Chunhua brand upright vacuum cleaner. The circuit consists of the following 2 parts: (1) Phase shifting circuit. R1, RP, and C2 form a phase shift circuit. When the voltage VC2 across C2 reaches the turning voltage of the trigger diode VD, VD turns on, C2 discharges, and the triac VS control electrode flows through a pulse current and is triggered to conduct. By adjusting the potentiometer RP, the phase of the control pole pulse can be adjusted to change the conduction angle of VS, thereby adjusting the motor voltage and controlling the speed of M. (2) Surge voltage absorption circuit. The motor M, which is an inductive load, has a phase lag in the load current. During commutation, a higher surge voltage is generated across VS. R2 and C3 form a surge voltage absorption circuit. S is the manual switch, XP is the power plug, and L is the inductor coil.
Latest Control Circuits Circuits
- What are the challenges in designing a permanent magnet linear generator?
- DC motor drive circuit composed of L293D
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Using P110C to control 6 DC motors simultaneously
- Starting method of asynchronous motor with external frequency-sensitive resistor
- One-way rotation circuit of motor controlled by contactor
- Infrared blocking alarm device
- Magnetic door and window anti-theft alarm
- Car audio system anti-theft circuit
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
