Automotive dedicated voice circuit LM-04YD
Source: InternetPublisher:fish001 Updated: 2018/12/23
The car-specific voice circuit LM-04YD solidifies four voice sentences: "Reverse, please pay attention", "Turn left, please pay attention", "Turn right, please pay attention", "Brake, please pay attention", and can independently trigger and control 4 segments. Voice output, while providing 4 output ports to control each LED flash. The picture shows the LM-04YD pins and its application circuit.
In the figure, the four trigger circuits are the same and are composed of resistor-capacitor voltage reduction, filtering, and diode voltage stabilizing circuits. R7 and C8 form the external resistor-capacitor components of IC1's internal oscillator. Appropriate adjustment of R7 can change the oscillation frequency to achieve the purpose of adjusting the speech pronunciation speed. The four output ports VOD1, VOD2, VOD3, and VOD4 are connected to external transistors VT1, VT2, VT3, and VT4 respectively, and directly drive J1, J2, J3, and J4 relays. The main contact of the Jl-J4 relay is a normally open type, ZD1 is the reversing indicator light, ZD2 is the left turn indicator light, ZD3 is the right turn indicator light, and ZD4 is the brake indicator light. The audio signal is output from the VO terminal of IC1. After being amplified by LM386, the speaker is pushed. The voice output and the corresponding indicator light flash at the same time to remind pedestrians to pay attention.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/656aade6-3c64-11ec-87b4-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/656b713a-3c64-11ec-80c5-086126841eb8.gif)
Latest Audio/Video Circuits Circuits
- Simple and practical small amplifier
- Single-ended Class A amplifier using gallstone composite tube design
- Two unique tube preamplifiers
- Make a pocket amplifier with 8550 and 8050
- Design and production of class AB headphone amplifier
- The production of 6P14 small tube amplifier
- Minimum output noise/reduced output power circuit using LM4910
- LM4902 differential input audio amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- American Grado RA1 headphone amplifier
Popular Circuits
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
