Portable alcohol tester circuit diagram
Source: InternetPublisher:石榴姐 Keywords: Special application circuit alcohol tester Updated: 2021/12/06
As long as the subject blows a breath through the sensor probe composed of a gas sensor, the tester can display the depth of the subject's intoxication and determine whether the subject is still fit to drive a vehicle. The circuit of a practical alcohol tester is shown in the figure, which is the ideal gas for a practical alcohol tester. The gas sensor is an MQ-Jl alcohol sensor, which is particularly sensitive to ethanol gas, so it is an ideal gas sensor for practical alcohol testing.
When the gas sensor cannot detect alcohol, the level applied to pin I⑤ is low; when the gas sensor detects alcohol, its internal resistance becomes low, causing the level of pin IC⑤ to become high. The IC is a display driver with a total of 10 output terminals, each of which can drive a light-emitting diode. The display driver IC determines the number of stages of lighting the LEDs based on the potential of pin ⑤. The higher the alcohol content, the greater the number of stages of lighting the diodes. The upper 5 LEDs are red, indicating that the safety level has been exceeded; the lower 5 LEDs are green, indicating the safety level, and the alcohol content does not exceed 0.05%.
Figure: Alcohol tester circuit
- How to connect TFT LCD to Raspberry Pi
- Building a Dehumidifier for a 3D Printing Dry Box
- How to Make a Pet Robot
- How to make a clock Bluetooth IOT speaker using Arduino
- Homemade video switcher
- Infrared detection type electronic rodent killer circuit
- A novel resonance demonstration device
- Making an Off-Grid Solar PV System
- How to create image processing solutions using HLS capabilities
- Discrete component laser driver circuit
- Common voltage comparator circuit diagram
- Production of forgotten item reminder circuit
- Typical electronic rodent killer circuit diagram
- Practical and efficient electronic mousetrap circuit diagram
- Portable alcohol tester circuit diagram
- Portable Breathalyzer
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
