SPI interface and microcontroller interface principle circuit diagram
Source: InternetPublisher:奥特man123 Keywords: Microcontroller power supply and other power circuits communications Updated: 2021/06/08
The SPI interface is a synchronous serial data transmission between the CPU and peripheral low-speed devices. Under the shift pulse of the master device, the data is transmitted bit by bit, with the high bit in front and the low bit in the back. It is full-duplex communication and the overall data transmission speed is It is faster than the I2C bus, and the speed can reach several Mbps.
For a 250μΩ shunt, the voltage signal at both ends is 250×40=10,000μV at 40A, which is 10mVRMS. The sampling signal is very small, so the channel gain should be set to the maximum, which is 32 times. At this time, the maximum signal input amplitude is 26.25mVRMS. .The actual maximum input signal is smaller than the allowed maximum input signal, and the shunt resistance value should be selected appropriately.
As the SPI bus master, LPC9401 outputs a clock signal, and STPM01 communicates according to the clock signal of SCLNLC. The following is a schematic diagram of the SPI interface and microcontroller interface provided by Shenzhen Jieduobang PCB Circuit Board Company.
![SPI interface and microcontroller interface principle circuit diagram](http://www.eeworld.com.cn/circuit/upload/9ae7bdd29de626dfac0e2001a5226e5d/45cb3c6766f00ea8ff1a3b2150da8df2.jpg)
- How to Make a Soft Latch Circuit
- In-depth analysis of DC-AC converter inverter
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- Boost drive circuit composed of RT8450
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Converting a lithium battery charging board into a constant voltage and current charger
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- About the working principle of single touch mode light switch
- Data transmission interface circuit design of automobile driving recorder
- Wiring of the power supply part of the microcontroller
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- Game console using SMC624A microcontroller
- Monitoring of 8048 microcontroller by WMS7705
- MAX703 and 704 constitute a microcontroller monitoring circuit
- Microcontroller universal digital tachometer circuit
