Wiring of the power supply part of the microcontroller
Source: InternetPublisher:狂妄火龙果 Keywords: Microcontroller wiring power supply BSP Updated: 2021/08/23
Using a high-precision voltage regulator and
correctly wiring it with the isolation transformer and low-pass filter can further improve
the anti-interference ability of the power supply. The wiring is shown in Figure 20-48
and Figure 20-49. In the figure, the choke coil (Li,
Lz) uses
an MX0-2000 magnetic ring with an inner diameter of 18mm, an outer diameter of 24mm, and a thickness of 8mm as the magnetic core. Li
and L2 are each wound with 50 to 70 turns.
- How to Make a Soft Latch Circuit
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- The constant current source composed of two transistors can drive high power
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- CNC regulated power supply production
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- Detailed explanation of mobile phone charger circuit diagram
- Analysis of rectifier circuit types and principles
- Agricultural temperature control circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Inductive feedback oscillator circuit
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
