Automatic hand washing machine circuit diagram
Source: InternetPublisher:三岁就很酷 Updated: 2013/05/28
The circuit principle of the automatic hand washing machine is shown in Figure 1. The 220V AC circuit is stepped down by the transformer T and becomes low-voltage AC. After rectification and filtering, it becomes low-voltage DC. It is then stabilized by the three-terminal integrated voltage stabilizing circuit 7806 to obtain 6V DC power to supply the control circuit. H1 is a red light-emitting diode, used as a power indicator. N2 is the infrared receiving circuit SFH506-38, N3 is the phase-locked loop audio decoder LM567, N3, R3 and C6 form an oscillator, R3 and R6 determine the center frequency of the internal voltage-controlled oscillator of N3, and pin 3 of LM567 is the signal input terminal, pin 8 is the logic output terminal, and its output terminal is the OC gate output. The maximum sink current is 100mA. The operating voltage of LM567 is 4.75V~9V, the operating frequency can be from a few tenths of Hz to 500 kilohertz, and the quiescent operating current is 8mA. . N4 is the NE555 timer, which forms a monostable timing circuit with peripheral components. Its purpose is to ensure the normal water discharge of the handwasher when the human hand occasionally deviates from the infrared detection range.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Benefits of Wide Bandgap Technology for Power Converters
- In-depth analysis of DC-AC converter inverter
- Single-power supply circuit for ISO122P/ISO124
- Miniature polarity reversal power supply using MAX1721
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Converting a lithium battery charging board into a constant voltage and current charger
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
