Wireless module usage circuit diagram
Source: InternetPublisher:3228 Updated: 2018/08/14
According to the circuit diagram of the wireless module, when there is no transmission, the DATA output of the receiving module should be at 0 level. However, with the one I bought, when there is no transmission signal, the DATA output of the receiver is messy. 0-5V changing signal. At first I thought the receiving module was bad, but after I replaced it, it was still the same. After turning off all the surrounding electrical appliances and removing interference, only the voltage is stabilized
The power supply and oscilloscope are still the same. But after connecting the transmitting module, as long as the signal (square wave) is transmitted, the receiver will not
There is clutter, and it is a square wave being emitted. After removing the transmitted signal (square wave), about 1-2 seconds later, the receiver has clutter again.
What I do is serial communication between PC and 89C52. Due to the existence of clutter, the microcontroller is always detecting serial port interruptions, which is very annoying. I don’t know what the reason is, can you guys give me some advice? Not grateful! ! !
In fact, I didn't have much hope for this module at first. It's only a small size and has only a few parts. Can it accurately transmit digital signals? Through practice, I feel that the effect is not as bad as imagined. For this module, I think we should pay attention to the following points:
The power supply is very important. Power supplies with large ripples must not be used. This is very important for the reception. The receiving module uses a 78L05 for power supply alone.
Secondly, it must be well isolated from the microcontroller, otherwise it will be affected by the frequency multiplication of the microcontroller's clock and even have no output signal.
There is also the need to connect its antenna. It is best to use a small telescopic antenna.
The preamble is very important. When I use it, the transmitting module is directly connected to RS232 through a level converter to send the signal sent by the computer. The microcontroller receives it. When the preamble is a space (that is, the data bits are all 0 and lasts for 20mM), the effect is Very good, but the effect is not good if the preamble is changed to something else. Logically speaking, a square wave (i.e. 01010...) should work, but the effect after the trial is not very satisfactory. As for the transmission distance, I haven't tested it yet.
- How about the boost converter TPS61299?
- Build a simple buck-boost regulator and test it on a breadboard
- Using Lead-acid Battery as Power Source for Walkman
- Single-power supply circuit for ISO122P/ISO124
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Constant current LED lamp driver circuit with soft start and anti-shock
- LNK304 non-isolated LED light string driver circuit
- 3~15V 10A adjustable voltage regulated power supply
- Practical constant current charger-----Constant current charger
- Homemade home inverter circuit diagram
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
