Light control, single button switch wall base circuit
Source: InternetPublisher:黄土马家 Updated: 2016/06/29
During the day, due to the high indoor brightness, the switch load (relay) does not work when the button is pressed.
At night or when the indoor brightness is dark, the load can start working by pressing the button switch. This means that whether the load starts after pressing the button
depends the brightness of the room. Once the load is started, regardless of the brightness of the room, However, pressing the key switch again can turn off the load.
PR is the brightness control and adjustment resistor. You can also increase or decrease the resistance value as needed.
The photoresistor should be installed in a position that is not blocked when the button is pressed (if possible, try to install it in a place that cannot be artificially blocked). Otherwise,
when the indoor brightness is high, the load will start accidentally after pressing the button.
- Benefits of Wide Bandgap Technology for Power Converters
- 220V Remote Load Monitor
- Step-down power supply for driving relays
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Homemade low-power UPS
- Car power 1.5V-12V six-speed converter
- Converting a lithium battery charging board into a constant voltage and current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- How to Select Modular EMI Filters for AC-DC Converters
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
