Motor waterproof protection circuit
Source: InternetPublisher:张三叔 Keywords: Power supply protection Updated: 2021/06/03
![Motor waterproof protection circuit](http://www.eeworld.com.cn/circuit/upload/a14fb5f56f0e2e8d0af4d6f1c5302966/83f2b4606d3752f475cd09802aeac6a2.jpg)
Water enters the motor and submerges the probe A. The water connects A to the casing. The relay K is closed, the normally closed contact is disconnected, KM loses power and is released, and the motor M stops. At the same time, HA sounds an alarm. Inform the staff to eliminate the water source, cut off the power switch, and dry the motor.
- ISO113 circuit that can reduce power consumption
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Use pulse width modulation to get a precise output voltage
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Boost drive circuit composed of RT8450
- Constant current charger using light emitting diode as voltage regulator
- Design of electric vehicle charger
- UC3842 Electric Vehicle Charger
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Importance of Voltage Supervisors and Output Topology Selection
- Asynchronous motor protection circuit composed of photoelectric coupler
- Typical Reference Voltage and Power Supply Circuits
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Recording level power supply circuit
- audio power circuit
- Single LTC power circuit
- Neon light high voltage power supply circuit
- 5V, 7.5V, 48V power circuit
- 6.3V, 270V, 300V DC power supply circuit
