Auxiliary audio power amplifier circuit design based on LM4730
Source: InternetPublisher:傻阿乐 Keywords: Power supply other power circuits Updated: 2021/12/25
Circuit principle: The picture shows the auxiliary audio power amplifier circuit of LM4730. The audio input signal passes through the potentiometers Rv, CIN and RB and then is added to the input terminal 8 of the LM4730. After amplification, it is output by pin 3 and sent to the speaker through L and R (the number in parentheses is the B pin number of the internal amplifier). Rv is the volume potentiometer, used to adjust the volume; RIN is to set the DC bias working point of the amplifier, and forms an input high-pass filter with CIN; RSN and CSN are used to reduce the instability of the high-end frequency of the amplifier; L, R It provides high impedance for high frequencies and low impedance channel for audio to prevent high frequency self-excitation.
- In-depth analysis of DC-AC converter inverter
- Using Lead-acid Battery as Power Source for Walkman
- Energy-saving motorcycle rectifier regulator
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED Driver ZD1680
- CNC regulated power supply production
- Car power 1.5V-12V six-speed converter
- Mc34063 MP3 Switching Charger
- Car Audio Power Supply
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
