AD7982 differential conversion single-ended signal circuit design
Source: InternetPublisher:拳制龙 Keywords: Power supply other power circuits Updated: 2021/10/02
Many applications require high-resolution, differential input ADCs to convert single-ended analog signals, whether bipolar or unipolar. This DC coupling circuit can convert a single-ended input signal into a differential signal and is suitable for driving the 18-bit, 1 MSPS device AD7982 in the PulSAR series ADC. Using the ADA4941-1 single-ended to differential driver and the ADR435 ultralow-noise 5.0 V reference, this circuit can accept many types of single-ended input signals, including bipolar or unipolar signals in the high-voltage to low-voltage range.
The differential input voltage range of the AD7982 is set by the voltage on the REF pin. When VREF = 5 V, the differential input voltage range is ±VREF = ±5 V. The voltage gain (or attenuation) from the single-ended source VIN to OUTP of the ADA4941-1 is set by the ratio of R2 to R1. The ratio of R2 to R1 should be equal to the ratio of VREF to the peak-to-peak input voltage VIN. When the single-ended input voltage is 10 V peak-to-peak and VREF = 5 V, the ratio of R2 to R1 should be 0.5. The signal on OUTN is the inversion of the OUTP signal. The absolute value of R1 determines the input impedance of the circuit. The feedback capacitor CF is selected based on the required signal bandwidth, which is approximately 1/(2πR2CF). The 20 Ω resistor and 2.7 nF capacitor form a 3 MHz single-pole low-pass noise filter. Resistors R3 and R4 set the common-mode voltage at the IN input of the AD7982. The figure below shows the single-ended to differential DC coupled driver circuit diagram.
![AD7982 differential conversion single-ended signal circuit design](http://www.eeworld.com.cn/circuit/upload/3238aef6a51d434df9e3b67be3557079/65287c65baa1340ee9047db4cd3265d9.jpg)
- How to Make a Soft Latch Circuit
- 220V Remote Load Monitor
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED rechargeable flashlight circuit diagram
- A novel and practical DC low voltage stabilized power supply
- CNC regulated power supply production
- Adjustable voltage power socket
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
