Battery fast charging control integrated circuit design
Source: InternetPublisher:蓝猫淘气 Keywords: Power charging circuit Updated: 2020/09/16
Circuit principle: The circuit provides +5V power supply voltage by a transformer, diode and voltage regulator IC7805. The battery voltage is divided by resistors R5 and R6 and then sent to the BAT end of the chip to provide a sampling voltage. The resistance of the resistor voltage divider network input to the BAT terminal should not be less than 200kΩ. When the TM terminal is grounded, the corresponding fast charge charging rate is 1C and the fast charge replenishment time is 80 minutes.
![Battery fast charging control integrated circuit design](http://www.eeworld.com.cn/circuit/upload/50f150338ee05b6305a5f49fc14c8e37/07da9ef9772f19e83fd7cf4675ec66cc.jpg)
- Analysis of the working principle of switching regulator
- A very convenient small power supply circuit to share
- Fabrication of multi-cell lithium battery charging circuit
- Basic circuit description of adjustable voltage regulator LM317
- Op amp power supply decoupling bypass measures
- Voltage-current converter constructed with XTR110
- Adjustable voltage power socket
- Adjustable voltage regulated power supply circuit
- MAX1811 Lithium Battery Charger Production
- Homemade home inverter circuit diagram
- Importance of Voltage Supervisors and Output Topology Selection
- Design of adjustable DC stabilized power supply circuit module
- Electronic regulator basic circuit
- DC 12V to AC 100V inverter power supply circuit design
- Single phase thyristor slotless nickel plated power circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- One of the transistor stabilized current power supply circuits
- Industrial four-way programmable controller power circuit
- Common power circuits and applications 06
- Common power circuits and applications 03
