Filament touch alarm circuit diagram
Source: InternetPublisher:笑流年 Keywords: Power communication power Updated: 2021/03/14
![Filament touch alarm circuit diagram](http://www.eeworld.com.cn/circuit/upload/9afcf7a1ae6f2761895f83c553d804ab/45ec1587e4d36621f9ad8f6d1e215786.jpg)
Use the circuit as shown in the figure to stretch very thin metal wires on both sides of doors and windows, or on both sides of aisles that need to be guarded. When someone breaks into the guarded area, the thin metal wires will be broken unknowingly. Trigger BG and thyristor, alarm DL alarm. For thin metal wire, 0.1MM thick enameled wire can be used. This circuit can also be used as a fire alarm. The method is to hang a wooden block with a rubber band. When the heat of the fire causes the rubber band to stretch, the wooden block breaks the metal wire and triggers an alarm.
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Detailed explanation of 5v charger circuit diagram
- Parallel DC regulated power supply circuit diagram
- Voltage-current converter constructed with XTR110
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Homemade low-power UPS
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- Detailed explanation of mobile phone charger circuit diagram
- Portable device charging power circuit design
- 3v to 5v circuit diagram
- Warm current power circuit a
- Super Class A power amplifier power circuit
- led drive power circuit
- Music power circuit
- DC-DC conversion power supply circuit
- 5V uninterruptible power supply circuit
- COMPAQ 420G type SVGA color display power supply circuit
