Complementary voltage switching class D power amplifier circuit
Source: InternetPublisher:zht24 Keywords: switch power amplifier circuit class D power amplifier Updated: 2021/09/13
The complementary voltage switching class D power amplifier circuit is shown in the figure. Transistors VT1 and VT2 are both 3DA12.
Among them, two same type (NPN) tubes are connected in series, and the VT of the body tube is 3DK41C.
A constant DC voltage VLr=12V is applied to the collector:
the input circuit passes through the high-frequency transformer Tl, so that I...this tube V'I. 1 and VT2 obtain
the reverse square wave excitation voltage. Since the voltage applied to the input terminals of two series n¨ij journal (NPN) transistors
is large enough and opposite in phase, the two transistors are in a switching state and conduct alternately.
The voltage across the loop is a square wave. The magnitude is equal to the DC power supply voltage V(Jc. k,
cJ form a high-Q series circuit to select the fundamental frequency. Therefore, this amplifier is called
a voltage switching class D amplifier.
- How to Build a Simple FM Radio Receiver on a Breadboard
- LM386 makes an AM radio
- FM transmitter in a matchbox
- Wireless doorbell production
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- XEl209 70~30 kHz Ultra-Low Power CMOS Transceiver
- RXM-433/418/315-LC-S Series Receiver Modules
- TR5100 FM 150~15 MHz transceiver
- MICRF500 FSK 1000~700 MHz Transceiver
- Dynamically biased high-fidelity power amplifier circuit (b)
- Dynamically biased high-fidelity power amplifier circuit (a)
- Two-stage difference amplifier OCL amplifier
- Installation using Bel Canto TA-1500 fever amplifier circuit board
- New tube amplifier push-pull amplifier circuit
- Feiyue 12D3 black and white TV audio OTL power amplifier circuit
- Application of differential amplifier circuit in OTL power amplifier circuit
- OCL quasi-complementary power amplifier circuit driven by op amp NE5532
- Making LM1875 DC negative feedback BTL power amplifier circuit
- TDA7053 power amplifier circuit
