Dynamically biased high-fidelity power amplifier circuit (a)
Source: InternetPublisher:赔钱虎 Keywords: Power amplifier circuit high fidelity bias circuit BSP Updated: 2021/10/01
It is a dynamically biased DC power amplifier
circuit driven by r.ePC1225H. The difference from the previous circuit is that the feedback capacitor is canceled and replaced by a DC servo circuit. Second, it changes the
adjustable bias circuit to super Class A dynamic bias, further improving the performance of the circuit.
The bias circuit is a substantial improvement of this amplifier circuit, using Class A super dynamic bias instead of the adjustable bias
circuit recommended by the manufacturer. Pins 7 and 8 of tjlPC1225H are bias terminals. The manufacturer recommends an ordinary adjustable bias circuit, which is internally
connected to the collector of the voltage driving amplifier stage and the base of the power amplifier output stage, so we can use pins 7 and 8. The terminal is connected to a super Class
A bias circuit , making the power amplifier circuit a super Class A power amplifier circuit .
- 18-inch large speaker
- 6AS7 tube amplifier
- A simple and practical tube amplifier
- Audio power amplifier circuit composed of LM4835/4838
- High gain audio amplifier circuit composed of LM4818
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- LM4820-6 audio power amplifier circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- Application of BTL power amplifier circuit composed of LM3886
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- Electronic thermometer circuit
- Rural vegetable greenhouse lighting circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Frequency modulator composed of NE566
- Double gate field effect transistor high frequency amplifier circuit
- superheterodyne radio circuit
- Guest arrival signal recognition circuit
- Fault signal trip circuit
