AM low power broadcast transmitter circuit
Source: InternetPublisher:萌面大虾 Keywords: Electromechanical low power broadcast transmitter Updated: 2021/09/26
The circuit consists of three circuits: audio oscillation (low-frequency amplification), high-frequency oscillation and modulation emission. The transistor VT1 and its peripheral
components constitute an RC phase-shifted oscillator. When the plug is inserted into socket CK, the RC oscillator becomes a low-frequency amplifier, and audio signals can be input from the outside and
amplified as low-frequency modulation signals.
RP and cs constitute an AC negative feedback network. Adjusting RP can continuously change the intensity of AC negative feedback, thereby changing the gain of the amplifier, thus
changing the amplitude of the output low-frequency oscillation signal or audio signal, so RP is called an amplitude adjustment potentiometer.
Transformer Tl can be the input transformer of the low amplifier circuit in the radio. Transistor VT2 and its peripheral components constitute a capacitor three-point oscillator
. The high-frequency constant-amplitude sinusoidal signal output by this circuit is used as a high-frequency carrier fc.
Transistor VT3 and its peripheral components constitute a modulation transmitter circuit . Since the threshold voltage of the emitter junction of the silicon tube is high, in order to improve the modulation sensitivity and reduce
the modulation distortion, an appropriate forward bias (o. 4 ~ 0.5V) is added to the emitter junction of VT3. Make it work in a Class C state close to Class B.
The AM low-power broadcast transmitter can be combined with the superheterodyne radio to form a simplex wireless intercom system.
- The main characteristics, advantages and disadvantages of IoT protocols
- Circuit principle and production of six-tube radio
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- Superheterodyne receiving module circuit using RX3310A
- MICRFl04 ASK 470~300 MHz Transmitter
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- TXl00 ASK 1 GHz~100 MHz transmitter module
- RXM-433/418/315-LC-P AM Receiver Module
- MAX2440/MAX2441/MAX2442 900 MHz Receivers
- Plastic bag sealing machine circuit
- Bus amplifier circuit using TDA2005S
- Transistor oscillation circuit for low power transmitter
- Fully automatic washing machine motor drive schematic diagram
- Homemade low-power electronic three-way active speaker
- Low power audio amplifier MC34119-02
- Adjustable DC-DC small power converter circuit (1)
- Digitally Tuned Low Power Filter
- 5V driven low power temperature compensated crystal oscillator
- Small power uninterruptible power supply circuit diagram
